Is there a program like vegas (or a plugin for vegas) that can edit avi files? because i caputre as AVI's but then i have to convert them to mpg to use in vegas.
thanks
Results 1 to 18 of 18
I've never had to convert to MPG to edit in vegas!!!! Don't know all what you mean there. Besideds, you would never want to edit MPG anyway.
Are you capturing from DV or analog and are you using Vegas to capture?
Once the footage is in the HD is obtained through Vegas, it automatically opens in Vegas. Now after editing, if you want an MPG file, then and only then do you convert your complete edit to MPG2 if you are then going to use Architec to author it to DVD/RNo DVD can withstand the power of DVDShrink along with AnyDVD! -
From now on when somebody say AVI, I'm assuming uncompressed. Sure Vegas will edit AVI files!
http://www.kiva.org/about -
You may be opening a religion war here....<grin>Originally Posted by Buddyboy
Most editors will handle AVI files, including the Sony product.
I have used Adobe Premier through several versions, from 5 to Pro. Recently, I purchased Puremotion's Editstudio 5. This is used to edit AVI files from my digital JVC camcorder, as was Premier. -
I am capturing from a VCR via composite video outputs....and i capture in WinAVI converter because thats waht ppl say is the best program...I cant edit those *.avi video files in vegas. I can import them into the asset box but only the audio shows up on the timeline...I guess i will try capturing with vegas
1 What capture specs are you using in WinAVI_Video_Converter? Something like 352x 240, YUY2 with 16bit 48KHz audio?Originally Posted by Buddyboy
2 What are the project settings in Vegas? Best if you use the same settings for project and capture format. Otherwise Vegas will need to convert your capture to the project format.
For example, if you capture uncompressed AVI, it is best to edit uncompressed AVI and then encode the result to MPeg2 for DVD.Recommends: Kiva.org - Loans that change lives.
oops!!...i meant i use WinDVD Creator 2 to capture, and then WinAVI Converter to convert th avi's to mpg's...and the only setting for AVIs in WinDVD Creator is AVI with AVI profile and I am using the NTSC DV template in Vegas...also I cant capture video in Vegas....i can hear the audio but no video shows up in the preview...and the capture butting is disabled
Also I am using a Leadtek Winfast Tv2000 deluxe capture card -
You need to rethink what you are doing. If I get this right you are doing this?
AVI uncompressed -> Mpeg2DVD -> DV - - - > ?? MPeg2DVD??
Why that?
If your goal is to edit in Vegas and make a DVD then
AVI capture 720x480 or 352x480, YUY2 etc 48kHz audio in Vegas or other program.
Edit in Vegas with same project format.
Encode DVD MPeg2 in Vegas or frameserve to a different encoder.
Then author the DVD.Recommends: Kiva.org - Loans that change lives.
I agree with the other posts here - capture to AVI, edit AVI, and convert to mpeg as the final step only if needed.Originally Posted by Buddyboy
Vegas will edit AVI files. If it won't read your AVI files, then something is not right in the setup with WinDVD Creator.
WinDVD Creator seems like an odd choice for capturing. Was there any other software supplied with the Leadtek card? -
You can't capture to DV format without a hardware codec (e.g. DV camcorder or ADVC). Computers won't be able to do that until CPU's go much faster, maybe in 2007-09?Originally Posted by Buddyboy
Set Vegas to project settings above.Recommends: Kiva.org - Loans that change lives.
I did capture to avi and i tried to edit it into vegas but it didnt work...i guess WinDVD Creator is the problem...i used that instead of the supplied winfast pvr becuase ppl said you could get better quality from windvd creator....and vegas doesnt wanna capture the video so i guess ill try the winfast pvr...i hop it works
alright heres waht the deal is:
Vegas isnt taking my uncompressed audio from WinDVD Creator or WinFast PVR...but as soon as i put any kinda codec in there vegas is fine with it...and so far huffy v2.2.0 has given me the best quality out of all the codecs...if theres a "codec" for uncompressed avi could i have it??...cause vegas isnt liking my uncompressed at all -
Huffyuv will work fine. It is a lossless compression codec.
Uncompressed settings describe the sampling and byte order. Examples are YUY2, UYVY (most common). You want 720x480 or 704x480, 29.97 fps. I have no idea what the selections are in WinDV Creator. Usually the capture card driver presents the capture selection choices
For audio look for WAV or PCM 16 bit 48KHz.
For Vegas, a project setting my look like this.
edited to show lower field firstRecommends: Kiva.org - Loans that change lives.
wow this really sucks now....the WinFast way isnt the most efficient...i can capture and import the videos properly using the huffy codec but i have to capture 5-10 mins at a time because any longer than that gives me a movie that is out of sync!....and i tried capturing with vegas but this is what it looks like
and windvd has absolutely no options for codecs or anything...just says avi -
See if you can find the card capture options in the Vegas Capture App - Video MenuOriginally Posted by Buddyboy
I can see all my ATI AIW options there with a ton of choices.
Maybe you need to reinstall the Leadtek Tv2000 driver or get a better one on their website.
Interesting side note, My ATI AIW levels are dead on with the tuner capture under Vegas.
OK...i have all of those options...but the crappy video comes when i use the RBG settings under color space/compression, UYVY isnt there and if i use the YUY2 setting then i get an error after i press stop after the capture. I have to use the I420 setting for it to work. Quality is great!...i really dont know why the YUY2 setting isnt working, and i guess the software/hardware of our capture cards must differ a lot...maybe ill just get another card but this will due for now....
THANK YOU VERY MUCH FOR YOU HELP!!!!
Help with editing an avi
By VanZan in forum EditingReplies: 6Last Post: 20th Nov 2011, 08:06 -
avi editing
By einarinari in forum Video ConversionReplies: 4Last Post: 18th Feb 2009, 16:06 -
Editing an .avi in FCP
By macmithos in forum MacReplies: 2Last Post: 20th Jul 2008, 16:27 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 20:16 -
Editing an AVI File
By solarblast in forum EditingReplies: 16Last Post: 18th Dec 2007, 15:52
