  1. How do you get rid of the menu on nero when you are burning a DVD. i tried one disc, and my PS2( yes my ps2, none of my other dvd players read DVD+R. but they read DVD-R) wont do past the menu, i click on the movie, then it just freezes.
    Apr 2003
    Maryland
    What MENU are you talking about?
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. You didn't give enough info, explain in detail what you are doing and what you want. You need to use Nero recode and select main movie only or the whole movie then burn it. The file it creates must be all together. The format of the dvd folder must also be valid , use dvd video and let Nero create VIDEO_TS folder for you.
  4. the DVD menu, the start page with the options to watch the movie. Like when you rent a movie, you can choose to watch the movie, or special features, or audio selection
    Apr 2003
    Maryland
    OK, I think I finally got it.
    You want to make a back up of a DVD without any menu???
    You want to go directly to the movie?
    If that's the case, Just use DVD Shrink, re-author mode, select the main title and drag it over to the left, click on backup, it will back up onoly the movie without menus. Burn it either with NERO Burning Rom or better yet, have Shrink create and ISO and burn that with DVD Decrypter. You can actually automate these functions if you have both a ROM and a burning drive.
    If this was not what you were asking than I'm back to square one.
  6. i'm guessing that is in nerovision, there is an option at the top right side when you have the options to change background and all that, i'not 100% on its location but i have used it so i know its there, if it's regular nero i have never seen a menu for dvd just vcd/svcd's
  7. If I make it an ISO, will my ps2 be able to read it and play the movie?
  8. i'm making the assumption that you are creating a dvd-video, but when you use the "make your own dvd-video" option in nero, you get the first screen where you can add video files, etc. on that screen, if you click the more button, an options box appears at the bottom and there is a "create menu on disc" check box, if you uncheck that, there will not be a menu on your dvd, it will simply start playing the video.
