How many dvds do I need to store an hour of .avi ?
Should be just one. What are you using? A DVD Recorder? If so You adjust the quality setting just like on a VCR. The longer the record time the worse it gets.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
It depends heavily on the avi. DV avi for example is about 12.5GB per hour of video. On the other other end of the spectrum is Divx in which an hour of video can be as small as 100-200mb.
For clarity, you are asking how many DVDs to store (no conversion) an hour long avi file?
Each DVD will hold about 4.3GB of Data. So for a 1 hour DV tape you will need (3) DVDs, provided you can split the file up fairly evenly between the (3) disks.bits -
Well, I figured he wanted to convert that 1 hour AVI to MPG at a reasonable bitrate and author it, and so that would fit just about in one DVD/r otherwise the 3 dvd/r housing split files is correct.
The original ? was a bit vague since you just only provided us with the Time length of the video. As has been said a million times, the term AVI can mean a lot of things so it could be a DIVX or XVID, other compressed forms or uncompressed in the case a 60 min DIVX/AVI, it would fit on a CD.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Depends on the size of the file. 8)Originally Posted by ushealer
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Can this machine transfer from tape to disc?
By Janowski in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2010, 14:23 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
