I have some vcds with very dark video and the audio echos or sounds like it was recorded in a hallway. Is there any way that I can improve the quality of the audio and video before converting to DVD?
Thanks in advance.
Not really. You could look at the virtualdub with the MSU deblocking filter (which seems to actually work pretty well on VCD source) and brightness/contrast filter to try and improve visual quality. You might be able to remove some of the echo in something like sound forge or audition.
But you are starting from very low quality source, and you should be prepared for the fact that you will get little return for your efforts.Read my blog here.
Is there any way to remove sound echo from a video?
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2011, 12:11 -
echo logfile question
By wiseant in forum ProgrammingReplies: 0Last Post: 17th Sep 2009, 19:42 -
remove echo from vcd?
By sharmine in forum AudioReplies: 1Last Post: 15th Nov 2007, 07:31 -
Audio echo with new hdtv
By frankhb in forum DVB / IPTVReplies: 2Last Post: 4th Aug 2007, 03:08 -
audio echo during capture
By caveman in forum AudioReplies: 0Last Post: 28th May 2007, 14:09
