Hello all,
Whenever i am trying to add forced subtitles to an AVI file (Xvid), the end result is desync of the video-audio-subtitles.
I set the subtitles frame rate to the proper frame rate, but i still get desyced between all three!!!
When I load the AVI I get the following message:
VirtualDub has detected an imporper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 16699 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed Wav file and recompress with a constant bitrate encoder. (bitrate: 114.5 +/- 13.2 kbps)
I understand the message but can someone Please write the steps I should take in order to get forced subtitles+synced audio.
Thanks.
After running this through on a couple of movies, I find my audio gets out of sync in the dubbing process. Is there a way to fix this?
Results 1 to 1 of 1
VirtualDub Sync Issue
By EzK in forum EditingReplies: 1Last Post: 13th Jul 2011, 12:30 -
audio sync issue with virtualdub
By tommcd64 in forum AudioReplies: 1Last Post: 18th Oct 2007, 15:09 -
audio not sync with virtualdub :(
By N3kr0 in forum EditingReplies: 0Last Post: 21st Jul 2007, 13:07 -
VirtualDub Audio Sync Issue?
By hech54 in forum EditingReplies: 2Last Post: 10th Jun 2007, 05:41 -
Virtualdub and audio sync
By Roy47 in forum Video ConversionReplies: 1Last Post: 30th May 2007, 08:57
