this happens only on the read not the burn,using a memorex +/-rw true 8x.was working fine for many months then started doing this more & more not always though.happens on discs I've burned many times,updated firmware & I thought it fixed it as a disc that wouldn't read then worked,But it's back doing the same thing
thanks for any ideas
jack
ps I reinstalled dvd decrip 2 diff versions as well
You are writing and erasing RW DVDs? I've only benn able to get about a dozen write erase burn cycles before before most rw discs enventually crap out.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
thanks for the reponse.I think the lens could need a cleaning
much appreciated -
More of a question than a reply:
I have lost the manual that came with my recorder and now I would like to "record over" some of the dvd +rw discs. Do I have to erase the programs already on the discs and then just record or is there a machine command that will tell the recorder what spot on the disc to replace?
Thanks, it is very tough to get these fancy machines to work without the book. -
If you were able to record more on the disc, it would be likely be added to the end of your recording. The software may be able to flag it to play back in place of a different clip, but that would be more like editing. If the disc hasn't been finalized, you may be able to put more on it.
I would just erase the RW and start over. If you wanted to save it for edit, it would be easier to transfer the file to a computer and edit it there. Then you can add or subtract what you want.
As far as a manual, have you tried a Google search for a PDF file of the manual? Most manufacturers also have them available on their website.
And if you have further questions, please start your own thread.
Can't burn CDs with ImgBurn - "Incompatible Medium Installed"
By Lawbringer in forum DVD & Blu-ray WritersReplies: 5Last Post: 11th Oct 2009, 17:35 -
Transferring HiDef DVC tapes TO ANOTHER HI DEF MEDIUM HD DVD/BlueRay/Other
By LCC0256 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Oct 2008, 16:49 -
decripter that brouses files not disc -freeware
By stonesnglass in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 18:35 -
Problem converting standalone incompatible clip but keep quality
By Mark69 in forum Video ConversionReplies: 6Last Post: 2nd Feb 2008, 11:15 -
Problem with Compatible video marked as incompatible
By nerys in forum Portable VideoReplies: 1Last Post: 4th Jun 2007, 01:01
