Results 1 to 13 of 13
  1. what can cause pixalation on a dvd?
    I know its not the media. I have some dvds I made about a month ago and they play fine but now anything I burn is pixalated.I have upgraded codecs since then but I'm not sure if they could cause the problem and if they can what codecs would cause it.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    capture error, codec, settings, bitrate
    among others
    http://www.kiva.org/about
  3. also I should have mentioned the dvds play fine on other dvd players
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Media then. Try some other/better disks.
  5. Originally Posted by ZippyP.
    I already said its not the media I have some from the same batch of dvds from a month ago and they play fine I also have tried other dvds and its the same results.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    player then. try cleaning the laser pickup
    Read my blog here.
  7. Originally Posted by guns1inger
    Is that the eye?
    What would be best way to clean it?
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can buy lens cleaning disks. Some have small brushes, others have small spongy or shammi type cleaners. I would go for that latter if you can find one.
    Read my blog here.
  9. Originally Posted by guns1inger
    Ok I'll try that thank you.
  10. Member edDV's Avatar
    Mar 2004
    If that doesn't work, ask your self what has changed since it last worked?
  11. Originally Posted by edDV
    It didn't work.I had updated a few codecs since it last worked.I can't remember exactly which ones though.
    What codecs should I look at first?
    What is a good program for viewing what codecs are installed and that can tell me when they were installed?
  12. Member edDV's Avatar
    Mar 2004
    Go back to the codecs that worked.
  13. Codec Sniper can tell you which codecs are "broken", also kill them.
    Pull! Bang! Darn!
