  1. I'm having a problem with using DVD shrink, after authoring my fiels with tmpeg enc, I use DVD shrink to get them down to size, its been working fine so far. But now I keep getting an error on one of my encodes,
    DVD SHRINK ENCOUNTERED AN ERROR AND CANNOT CONTINUE
    Programming error - exception occurred
    Does anyone know the reason for this error and how to stop it. it occours at the 99% of the re-encode, I cant think of any reason for it. the Mpegs are fine and the first encode out of tmpeg enc seems fine.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What are you authoring with ?
    Also FWIW IMHO you'd be much better off hitting the correct target size first time, in TMPGEnc, instead of relying on DVDShrink.
    If in doubt, Google it.
