hello!
I have a dvd as a set of vob etc files in the AUDIO_TS (empty) and VIDEO_TS folders
I want to burn it in a DVD, but the DVD will have enough space to write some wmv and avi's as well.
how can I write them? simply add the folders and files to a DVD ISO in Nero? will all be playable to my stand-alone dvd player?
thanks!
yes you can add them in their own folder IF there is enough room ..
not a problem"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thank you!
is it necessary to add the avi's in a folder? can the dvd just contain the AUDIO_TS and VIDEO_TS folders and the avi's (not in a folder) ? -
yep - you can do that
if the avi is over 2 gb , you will have to make a UDF disk , not a UDF/ ISO hybrid ..
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 04:23 -
avi's to a dvd disk
By Rich2010 in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2009, 19:50 -
combining .VOB files for DVD player disk
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 12th Apr 2008, 06:39 -
VOB to AVI back to VOB
By fatla00 in forum Authoring (DVD)Replies: 23Last Post: 11th Oct 2007, 03:28 -
Dummy VOB, full disk extraction...cannot be done
By sknox in forum MacReplies: 11Last Post: 9th Oct 2007, 21:36
