Results 1 to 9 of 9
    Dec 2001
    Hi, i have a little problem.. Iīve burn a VCD using VCDEasy (best result with this one, also used Nero !!)
    I burn a standard VCD 1.1. My standalone dvd player (thomson dth3300) recognise this disc and displays Video CD 1.1. And then shows number of tracks that i have burn. But when i try 2 play one of these tracks nothing happends, it just keep seeking 4-ever.
    I use tmpgen to decode to mpeg with a standard PALVCD-template.. What am i doing wrong ?? Please Help !!!
    Best regards A.M
    Feel free 2 email me at: the-beast@telia.com
  2. First play your VCD with some sofware player on you PC. If you don't have any, open Windows media player and open .dat file from your VCD (CD-ROM). If it not playes then something wrong with your conversion/authoring process
    Dec 2001
    I have tried it, but the media-player plays them without problems..
    Thanx anyway...
  4. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    I am having the same problem. I can play the mpeg. But when burning with NERO 5.0 I cannot play the vcd. just sits there and spins. I even tried to multiplex but still no banana. What could I possibly be doing wrong????
  5. if you are using CDR then may be your dvd players done read them well. Please try to create on a CDRW and Try to play it
    Baskaran Swamiappan
    Englewood,CO
    baskis@gmail.com
    Dec 2001
    I have tried both medias (CDR and CDRW), and itīs only CDRW-discs that work.. It recognise the disc as a Video CD 1.1 and find the tracks, but doesnīt play them..
  7. The most likely reason for your problems (as others have alluded to) is that your DVD player can't read CD-R/W media well.
    Try to burn an audio CD on the same media and see how well that plays...
    You will probably have to experiment with different brands of media to find one that works. CD-RW often works better in these circumstances.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Dec 2001
    I tried to burn a ordinary music cd, and same as before..
    Recognise as a Audio Cd, how many tracks and total playing time..
    But when i try to play a track poor result.. But a funny thing was that when i fastforward a track at 4x i could hear some sound from the song..But when i play it in normal speed it just spins and spins.. WHY ??
    It almost seems like i get better result everytime i Rewrite the CDRW. I use a brand called LEAD DATA SILVER BLUE Professional. How many times can you Rewrite a CDRW ??
    Best regards A.M
    the-beast@telia.com
  9. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    On 2001-12-21 03:34:16, the-beast wrote:
    But when i play it in normal speed it just spins and spins.. WHY ??</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    As I stated before, your DVD player was not designed to read CD-R or CD-RW media and not surprisingly it doesn't do so well.
    Regards.
    Michael Tam
