I have say 10 tv cartoons all of mpg format.
Put all 10 in the VTS layout section.
Clicked on auto layout option.
S2D has now sorted them out thus creating 10 VTS Movie reels on the left hand side.
I clicked on quick dvd "no Menu" and it did its stuff but when i played it within Windows Media Player it would play the first cartoon and then stop as if there was only 1 cartoon on the disc.
I burnt it to a disc but it will still only play the first cartoon and stop.
Any suggestions on this please.
In my settings under the process tab i have noticed the there is no dot/tick in MERGE TITLES IN A TITLE SET BEFORE AUTHORING ?.
Not sure what it does but thought i would tell you this anyway.
You have 10 TitleSets. Without a menu you need a player capable of navigating to those TitleSets. This differs from player to player but most have some remote buttons to navigate via "Titles"
I thought that the way i did it the cartoons would just play one after another ?.
Is this possible if it was done a different way.
If they were all the same frame rate and bit rate etc i could possibly join them ?? -
S2D converts different formats of the assets to a common one before creating the DVD folders. So if you wish to have the 10 cartoons play one after another, tick on the Merge Titlesets button before you start the project
(that is if you don't wish to use the Menu method) -
Ok, if you want to thave the 10 cartoons to play sequentially you need to do one of the following:
1. Have 10 TitleSets, as you have currently, but create a menu and add a "Play All" button.
2. Create the DVD structure manually and put all your 10 assets in the same TitleSet. If you do it this way you don't need a menu & you can optionally do the "merge titlesets" if you find that this improves playback on your player.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ok did that and worked well but no sound on pc only on dvd standalone.
Cheers. -
What software do you use to play DVDs? Is it AC3? Do you have the correct codec?
DVDSubEdit... Everything Is Wrong!!!
By Typhoon859 in forum SubtitleReplies: 18Last Post: 5th May 2009, 08:08 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
