Hi,
I've just been on a holiday to Florida and recorded loads of stuff which i have edited and created quite an interesting video, however there is one problem, I cannot figure out how to drop and increase the volume at specific points in the movie,
e.g. I have background music, but then i have video footage of a show with music, so how can i drop the background musics volume and increase the shows music so that they dont clash horribly???
Thanks, Joel
=D
are these on the same track ? if so -- you will have to separate them somehow ...
if different tracks - just use either automation or track audio volume envelopes and set points where you want the volume to differ and drag the line as you need ..
with automation you can adjust the whole thing as it is playing in real time ..
both of these are covered in the manual and training courses and help files .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39 -
All-in-One Volume Control? Vegas 6
By solarblast in forum AudioReplies: 2Last Post: 6th Dec 2008, 09:07 -
Sony Vegas 9.0 Platinum how do I raise and lower the volume?
By LoveMyslf in forum EditingReplies: 1Last Post: 7th Nov 2008, 12:28 -
Vegas 8 volume envelope help
By stantheman1976 in forum AudioReplies: 3Last Post: 22nd Jun 2008, 21:29 -
Video format and volume problems
By mikehende in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2008, 07:06
