My DV Camcorder manual (Pansonic PV-GS65) says,
Is this one of those "CYA" warnings, to limit Panasonic's liability in the remote and unlikely case that someone experiences a problem; or is this a valid warning I should heed?Before making these [computer to camcorder] connections, turn off all devices which are to be connected.
I've got a Win2K Dell which takes a relatively long time to reboot; and I'd like to plug and play, as long as I'm not going to turn either or both of my devices into toast.
Anyone have experience/insights to share?
Thanks,
JeffD
A computer is not considered a device, at least not in this context.Originally Posted by JeffD
Just turn the camcorder off. That is what you are protecting.
FWIW: I power down my expensive camcorder before connection but don't bother with an old Digital 8. Nothing bad has happened yet but others have complained of fried IEEE-1394 connections.
Risk is greatest if you have other devices connected to the camcorder such as a TV or a VCR.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Originally Posted by thecoalmanThanks, guys.Originally Posted by edDV
JeffD -
yep..i don't know about your particular model..but the panasonics seem to have a bad reputation of blown out firewire ports. mine was blown out from day 1 even though the port had never been used. I also heard on the pana3ccd forum that panasonic considers the firewire port an extra luxury.
Connecting more HDDs to the Computer Uses More Power?
By imdaman in forum ComputerReplies: 12Last Post: 13th Dec 2010, 00:06 -
Is my camcorder's lithium ion battery power diminishing?
By Nintendo Fan in forum MediaReplies: 5Last Post: 17th Mar 2010, 20:03 -
Power cables of camcorder...
By 1234567 in forum Off topicReplies: 5Last Post: 22nd Dec 2008, 10:11 -
Mac user needs help connecting MiniDV camcorder to a PC & what software
By KeepItSimple in forum MacReplies: 1Last Post: 18th Aug 2007, 20:04 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
