I'm new to this. Basically, I gather that a VCD menu is not like most DVD menus, with selectable items on the screen, but rather just a guide, telling you what will happen if you choose certain things. Is this correct? And does the menu take the place of track 1? I'm having trouble visualizing how it al works, and I think that in addition to all these guides on how to create menus, there should be something more basic on how they work. If there is already such a guide, I'd appreciate it if they could throw a link my way.
<font size=-1>[ This Message was edited by: DiGNAN17 on 2001-12-20 08:15:12 ]</font>
(S)VCD menu is something like you select given number in your menu to go to the track you desire. Unlike DVD menu you cannot use up-down arrow but you still can use skip>>, <<skip, play/enter, and stop.
You can read this topic which is all about Menu and TSCV
https://www.videohelp.com/phpBB/viewtopic.php?topic=60806&forum=1 -
You are right. Menu will take the place of track 1.
To know about menu, search "phillips VCD authoring" on google or any search engine. It will throw you links.
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
How can I create this very simple menu with Multiavchd?
By alc112 in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jul 2010, 13:26 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Simple DVD Menu
By Burner2009 in forum Authoring (DVD)Replies: 5Last Post: 21st Nov 2008, 13:47 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 05:12
