Ok well I upgraded to MMC 8.9 with the new display and capture drivers, before I installed the 2 drivers tho the record button was still there and now that I installed it its gone.
Results 31 to 40 of 40
ok well ATI MMC pissed me off enough with just trying to get the record button working, I was able to record successful a commerical wrestling tape without any signs of MV in it, so no dark and light and all those stuff.
Originally Posted by StoneColdWhat
Half D1 (352x576 PAL or 352x480 NTSC) with 2-pass vbr and an average bitrate around 3000 kbit/s seems OK for VHS source.Regards,
Rob -
Hmm i dont know whats wrong but i cant get MMC 8.7 installer to work, is it possible it has something to do with SP2 or with my X800XT?
Tjena -
If you can't run ATI's software, then your problems are more than their software. Try building a decent machine and it will be bullet-proof. I hear this complaint all the time about ATI's MMC and either I must live on a different planet or I am doing something different.
SP2 has a huge bug list. Installing it on an "unclean" system is a disaster waiting to happen too. Not like installing OS, then SP1, then SP2.
As far as i concern i have a deasent machine 8)
I installed it with SP2 integrated. But i dont know the problem since the newest version work. Can it maybe have something to do with PCI-Express?Tjena -
It sounds like you had a newer version of MMC on your computer. Are you sure you completely removed it before trying to go to the earlier version? ATI software and drviers are also notorious for not installing right unless you make sure you got rid of ALL of the previous install before performing the new install.
Yea im pretty sure, the funnt thing is that the installer didnt load at all i double-clicked it came up and went down. Hmm i try downloading it again and see what happens.
Tjena
Quick question on quality and file size...
By rxloren in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2010, 19:26 -
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
any advice on quick and dirty vhs conversion to dvd?
By cheap in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2009, 19:29 -
VHS -> DVD question on quality.
By Oob in forum RestorationReplies: 9Last Post: 18th Apr 2009, 23:40 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13
