Hi,
I hope someone has some ideas, but i hve had an LG GSA 4160B DVD Super Burner for several months now, and not had any problems really apart from the odd DAta Cylinder error or whatever, but i have noticed in the last week or so, the drive although working fine, is burning (and reading) REALLY slowly, for example when using Nero to burn a DVD, which used to take like 7 or 8 minutes, it is now taking like 45????? Although Nero still shows it as burning at 8x, also the "time Remaining" counts down to 0:00, then stays at that for like 5 minutes then updates to jowever long is left (usually 15 minutes). I have tried uninstalling and reinstalling the drive, but no change.
Any Ideas?????
My System:- AMD Sempron 2800+ 2.00 Ghz 352Mb RAM
Windows XP Pro.
MM
Ok i tried changiong the setting to DMA in the advanced settings tab on Device Properties for the IDE channes, the first one reads Ultra DMA 5 on both device 0 and 1, and the second channel reads Device 0 set to DMA if available, but showing PIO, and device 1 is set to DMA if available, showing UYltra DMA 5. It now seems to rip fast again, but it still burns slowly (after resetting)?????
MM -
Hit the registy... This link will help...
https://www.videohelp.com/forum/viewtopic.php?t=187112
Media Player Classic suddenly extremely slow menu
By brucend75 in forum Software PlayingReplies: 6Last Post: 30th Dec 2011, 22:56 -
convertxtodvd suddenly runs very slow
By aruwin in forum Video ConversionReplies: 13Last Post: 25th Jul 2009, 02:39 -
Problems with DVD LG GSA-4160B
By Jomapil in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Feb 2009, 00:33 -
Video conversion suddenly became too slow.
By syedmahm in forum Video ConversionReplies: 6Last Post: 28th Aug 2008, 09:37 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
