I would like to install Google Desktop:
http://desktop.google.com
But when I try to install it says that SpamSubtract is interfering with the installer and that I should remove it. SpamSubtract is something that came preinstalled with my computer and I've never used it and don't want it on there. I tried uninstalling it but it says "Error, cannot find Install.log". I then found SpSubLSP.dll, its dll file in windows/system32/, and manually deleted that and the folder in program files. I then rebooted but Google Desktop still gave me the same error. Any idea how to get SpamSubtract completely off my system so I can install Google Desktop?
Results 1 to 12 of 12
Well, if It came W/ your computer, could it be in your "Add/Remove Win XP devices?"
Just a thought.WIN XP (2)
WIN 98 (1)
WIN 95 <-Multiple Computers
WIN 3.1 <-Multiple Computers
Redhat Linux 7 (New To This)
Apple IIe -
I think thats what he meant when he said it gave him the error cannot find install.log.
Only real hope is to find the program out there somewhere. Hopefully they either have removal instructions or you can download it, install it, then uninstall it properly.
This is why all store purchased machines get formatted and manually setup with me. Even Macs. -
Exactly, the uninstaller fails. Unfortunately I cannot find any documentation on it either.Originally Posted by Flaystus
http://www.intermute.com/products/spamsubtract.html
Try to download and install the trial. Then remove the trial. See if that gets it. -
Any Luck Garibaldi?
WIN XP (2)
WIN 98 (1)
Apple IIe -
I don't trust Google.
For searching, I use Google via the scraper:
http://www.scroogle.org/scraper.html
I know little about the Google desktop, sorry -
I don't trust your scraper. What are THEY getting out of the deal?Originally Posted by offline
@ Garibaldi
You might have to clean your registery by hand by checking all associated keys, runing msconfig to remove it from startup and sysconfig to check the .ini's
@ Faustus, I don't wish to hijack this thread
You could also try the progam ccleaner (it is free) to remove the program/reminants.
Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
isn't Garibaldi's post from August last year?Originally Posted by offline
I hope he still isn't trying to fix this without ever having left his PC as that's commitment
scroogle looks interesting 8) -
Hey thanks guys for checking back up on this! I actually somehow got it unistalled and then forgot about it. Either that or its still on here but the new version of google desktop doesn't have a problem with it. I used it for a big but now I'm using desktopsidebar:
www.desktopsidebar.com , I like it a bit better
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 07:31 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 15:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 14:59 -
How to uninstall a DVD burner
By DVinci in forum DVD & Blu-ray WritersReplies: 2Last Post: 25th Dec 2007, 22:34 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 09:55
