This is getting really old, about halfway through, I get a popup that says "Windvd creator has an error and must close".
ANy ideas on this>?
You are in breach of the forum rules and are being issued with a formal warning. Don't cross post. Only post a problem once, in the correct forum, and wait for an answer. Continue all related discussion in the same thread. If you get no answers after a couple days, bump it at that time.
/ Moderator lordsmurf
Shot in the dark... Out of Hard Drive space? I don't use Windvd Creator myself, but usually there is a target drive that you are compiling to. Then there's also a temp drive/directory that the program uses as a work space. If either one of these drives doesn't have enough available space it will cause problems.
Buy My Books -
Thanks. Harddrive space is good. Hmm.
Are there any other programs I can use to extract bin files, etc?
I know have tow .dat files that I want to join and burn to DVD so the movie plays. I can play the .dat files in win media player and they work, but I want to watch this on a DVD and have it play.
Can NERO do this? Help -
Someone replied with some other programs that will do the same thing as windvd creator. Can someone list them again?
I need to take multiple MPEG and AVI'S and be able to make a playble DVD in a home DVD player.
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 13:38 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 19:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 06:39 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 22:43 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 17:15
