Hello,
I have a home movie DVD I created using iDVD (probably version 2...I can't remember). I have tried using OSeX, YadeX and MTR to rip the DVD back to my hard drive (for conversion to DiVX format to play through EyeHome).
Each ripper rips the video fine, but the audio is messed up. Quicktime doesn't understand it at all and VLC plays it, but it's garbled horribly.
Any thoughts?
Thanks!
You don't need to rip the DVD to the hard drive to read its VOBs because it isn't copy protected.
If you have Toast 7 you can simply choose the DVD in the Media Browser, drag your movie to the Toast Video window, select it and export to Divx or burn a Divx disc.
Other applications such as MPEG Streamclip can export the video directly from your DVD. -
Another choice is Cinematize, which usually does a good job at extracting DVD data to QuickTime.
as frobozz says... this is trivial to do with toast 7... and no need to spend extra $ on cinematize or others.
Thanks to all for the info. I have been busy dealing with Katrina and have not had a chance to check back.
Problems ripping multiple VRO titles from Samsung created DVD-RW
By brancusi in forum DVD RippingReplies: 5Last Post: 8th Mar 2012, 12:19 -
iDVD Created DVD without Sound on DVD Players
By Doctor X in forum MacReplies: 13Last Post: 12th Mar 2011, 03:51 -
Help ripping DVD created from GoVideo
By stryker412 in forum DVD RippingReplies: 5Last Post: 13th Apr 2010, 14:42 -
idvd and ripping dvds
By gillomax in forum MacReplies: 3Last Post: 29th Sep 2009, 10:22 -
DVD created by iDVD doesn't contain audio when the footage is HDV
By vansrikanth in forum MacReplies: 1Last Post: 6th May 2007, 12:38
