Hello
I have a movie whose bitrate is larger than 8000.
I need to get the bitrate set to 8000 or less.
Can anyone please tell me how to do this step by step?
Since im a newbie on this, i find many on the tutorials a bit confusing, and therefore prefer "living" people to help me.
I have a dvd movie on a dvd-r ( legal backup of previously bought movie).
What programs should i use, and briefly how shouuld i use them to get the bitrate i want? Aftter having changed the bitrate, how do i get all the files back to a new dvd-r again, playable on my standalone dvd-player.
Would really appreciate if someone could walk me through this, step by step.
Best regards:
Results 1 to 21 of 21
Convert the DVD back to MPEG file(s) using https://www.videohelp.com/forum/viewtopic.php?t=224833#tmpgencdvdauthorereauthor .
Re-encode the MPEG file(s) to MPEG file(s) but using a lower bitrate using htt://members.dodo.net.au/~jimmalenko/AVI2DVD.htm .
Author new DVD using your favorite authoring software.If in doubt, Google it. -
Hello
Thanx for your reply.
I will look into your answer during the weekend.
Chances are very high i will post more questions here if i encounter any problems...( most likely )
Best regards: -
DVD Shrink and reduce the target size. No need to demux, reauthor etc.
Read my blog here.
That's perfect if he wants to reduce the file size only to make it fit a disc. I'm not sure but I think he might be wanting to reencode at a lower bitrate for whatever the reason. He did not explain why. In that case, DVD to MPG to Encoder and back to whatever.
I think!!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Hello
I now have got a mpeg-file after using Dvd Re author. What program should i use to load the mpeg-file and set my wanted bitrate for the movie, before i make it a dvd agaiN?
Best regards: -
Thanx for reply.
I will try using Tmpgenc to do this, even though i havent managed to find out how i do it earlier.
But, i wonder..what is the difference between Constant Bitrate and Variable Bit Rate?
If i want a movie not to get a higher bitrate than 8000 in any part of the movie, should i then choose 8000 cbr instead of 8000 vbr.
Are there any disadvantages in using cbr ?
Best regards: -
Damn..Now i get the errormessage:
"Couldnt create the file...."xxxxxxxxxx.m2v" Urk -
For VBR, 8000 as max should work, but if you have the space, 8000 CBR will be even better.
/Mats -
Im even getting errormessages when trying to load the f... mpeg-file...doesnt help what i set as bitrate under Settings, heh
Hello
Thanx for the reply.
I have tried setting their priorities to max, without that helping anything im afraid.
Has not tried your other suggestion, might try that.
But, isnt it any easier way changing the bitrate to a dvd-r movie?
That is what this is all about.
I have a dvd-r movie with a bitrate of 8500.
I want to change the bitrate to 8000 for the whole movie.
What is the easiest way to do this?
Appreciate any help. -
The ONLY way you can change the bitrate is to re-encode, and that requires an encoder. I hate to say it (and I mean this in the nicest possible way) but you gotta be doing something wrong - it's not as hard as you're making it seem.Originally Posted by pellets
So why do you need to lower the bitrate 500kbps ?
Hello
I also think i must be doing something wrong, i just cant figure out exactly what im doing wrong.
Could you please educate me on how i proceed after having demuxed the dvdr-movie?
I used dvd-decrypter to demux the video and the ac3-file.
As a result i get 4 m2v-files and one ac3-file.
I dont know what program to use, in order to set the wanted bitrate in the 4 m2v-files.
Could u please educate me on the best program ( and the easiest i hope...) to use, in order to be able to set the wanted bitrate on the 4 m2v-files ? Would apperciate if you could do this, and tell me in a very thorough way how i should use the program to do it?
( The guides here i find a lot confusing)
I want to change the bitrate, because i need the bitrate under 8000 in order to be able to watch the movie on my standalone dvd-player without getting choppy picture and sound.
Best regards:
Best regards -
You can use a transcoder such as rejig or shrink to reduce bitrate - just choose a target size that forces the bitrate down to the correct amount. Lower bitrate = smaller file size. It is using these programs backwards, but the outcome will be the same, and with a lot less headaches than you are currently having.
If you want to keep going the hard way, try loading your m2v files into virtualdubmpeg and frameserving to tmpgenc.Read my blog here.
I am very confused here!
Just WHY was it you wanted to reduce the bit rate in the first place. When one considers that reducing bit rate generally will tend to reduce overall quality, all things being equal.
Again, WHY are you doing this?? Just wondering as you seem to be going through a very painfull process to achieve this and I simply can't see why!No DVD can withstand the power of DVDShrink along with AnyDVD! -
I want to reduce the bitrate to 8000, because thats the only way im gonna play some of my dvd-r on my standalone dvd-player without getting choppy picture and sound.
To gunslinger:
you wnated me to use virtualdummpeg. How do i use this program to set the bitrate? Can u please tell he how to do this thoroughly ?
What did u mean by freamserverving? And, did you want me to use tmpgenc also? In what way?
Best regards:
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 22:25 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 06:59 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 10:32 -
How to reduce video bitrate ?
By Sean-- in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2007, 05:47
