I can record TV programs onto my hard drive as 'film.mpg' files using a ComproDTV 2.5 PCI TV card in the UK.
The films play back very well on Real One player on the computer but I have problems when I burn them to a DVD to watch through a JVC Video recorder on the TV. If I select DVD-video in Nero 6 to burn the DVD a message says that the file is bigger than 2GB and cannot be stored in an ISO file system and I must use UDF. My JVC DR-M10 player will not accept Packet Write (UDF) format discs and so they won’t play.
Why if a DVD can store 4.7 GB of data can’t I write a 2.5GB film to a DVD? How else can I get my TV recorded programs onto a DVD to view on my TV through my JVC player?
My burner is a Sony DVD-RW DW-22A and I am using Nero 6.0.0.28
You must author it to a dvd-video first,
https://www.videohelp.com/tools?s=2#2
https://www.videohelp.com/author#3;6
nero burning rom or nero express can not author. tmpgenc dvd author is very easy to use but you can try nerovision express if it is included with your nero. -
Thanks Baldrick, as the post suggests I'm a newbie and I haven't heard of authoring before. I have followed some of the links and am still in the dark as to what's involved. Any chance of supplying a simple explanation and some software recomendations? I have just discovered that my version of Nerovision express has expired and I haven't even used it!
New to the video burning scene
By Jamie218 in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2010, 16:20 -
Help with burning a video ts folder
By molinman in forum Newbie / General discussionsReplies: 4Last Post: 15th Dec 2008, 03:39 -
Burning HD Video to BluRay
By frogger0528 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 25th Nov 2007, 13:07 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19 -
help burning video ts folder?
By pbure0110 in forum Video ConversionReplies: 3Last Post: 21st Jun 2007, 22:39
