ok boys getting close now.
pinnacle kicks butt capture as avi then make movie as vcd and very good quality
if anyone knows how to capture right to vcd with that quality tell me
in lieu of that i am running XP so the 4.0gig limit should not be a problem ...........but it is even though i set time in pinnacle to capture 60mins......it quit at 3.99gigs which was about 15mins of .avi
1. how can i tell pinnacle its ok i have xp
2. if i cant do that how can i get pinnacle to capture in
mpeg2 or mpeg 1 format will do it that way
thanks
me
Well, I can't help you with the file size limitation, but I still think you can get past your problem. I suggest you use huffyuv (lossless) compression. Your avi file will be almost half the size. You should be able to get 30 mins inside of 4 gigs using huffyuv. Further, if you go with mjpeg (lossy, but good) compression, you should get even more.
Darryl
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 19:30 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29 -
Pinnacle studio 11 capture problems...
By bla4free in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2008, 10:09 -
Pinnacle studio 8 capture problems
By bimfi in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2007, 15:27
