Can someone tell me how to tell which video encoder my pc is using? I can't seem to find the answer to this in a search.
Thanks,
Lonn
...but perhaps you mean "decoder"?
I think Mediaplayer Classic can report what codecs in play when playing back video.
/Mats -
I'm using a Canopus advc300 to capture video into Vegas 4 + DVD as avi files. Then use Vegas to put all the captured files together as one move and produce an mpeg2 file which is then imported into DVD Architect Studio 2.0 to aurthor and burn. How do I know which encoder DVD Architect is using to encode the video. Or was that done when Vegas made the mpeg2 file, and if so how do I tell which encoder Vegas uses?
Thanks,
Lonn -
noOriginally Posted by VERVE"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Freemake video encoder video gets green screen
By flashcabaja64 in forum Video ConversionReplies: 7Last Post: 20th Mar 2012, 21:23 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 09:09 -
Help with video encoder
By massivegroove in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2007, 10:59 -
Video EnCoDer!!
By Unkn0wn in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 11:57
