Is there any way to watch and record Directv on a mac?
You'll definitely need a DirecTv dish and tuner, but if you then had some kind of video input card in the Mac you could feed the video from the tuner into it. Recording it is going to require enormous amounts of disk space unless you have some way of doing on-the-fly compression. That normally reuires dedicated hardware, as in a stand-alone DVD recorder, but maybe there's a solution out there.
If the DirecTV tuner has a working Firewire output, you can record direct streams without additional compression. This is, however, unlikely.
As alternatives, you can employ a converters (analog to DV, or analog to MPEG). The most recommended are Canopus for DV, and ADS Instant USB to DVD (or something like that) for MPEG. -
I do it this way.
I record the show on my Digital Video Recorder that also burns DVD's.
I burn a DVD off of the Digital Video Recorder.
I watch the DVD in my Mac.
I dont see any other way of doing this and why would you want to do this on a Mac anyway?Mark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
I use Alchemy DVR, which utilized a TV Tuner card that you can just pop into a slot on your powermac...it comes with a recording utililty, much like a Tivo that you can even sync with your iCal. It's a great little program...but somewhat cpu intensive from what i've read. I have twin 2.7's and 700gb of hard drive space, but have never noticed any slow down's in whatever I'm doing while it's recording.
JPT
CRT TVand Sony recorder HDC500 can't watch and record in HD Help
By Glasswitch in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2010, 00:34 -
DirecTV DVR: how do I get to my computer to record to DVD?
By hyphenate in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Dec 2009, 09:54 -
Is it possible to record a channel you cannot watch?
By showmi in forum DVD & Blu-ray RecordersReplies: 11Last Post: 7th Sep 2008, 00:13 -
The best card to watch/record HDTV?
By Chuck_Johnson in forum DVB / IPTVReplies: 31Last Post: 9th Feb 2008, 11:05 -
Watch one channel, Record Another
By NYWino in forum Newbie / General discussionsReplies: 12Last Post: 10th Jul 2007, 15:54
