I have an avi and a srt file that I'd like to burn to a DVD.
I usually use TMPGenc to convert the avi to m2v ..the audio I extract and convert to AC3 - then burn these with TDA.
What the heck do I do with the .srt file? How do I get the subs on the DVD as well? I'm assuming its done in the authoring..but really have no idea.
I've searched and saw one other post about the srt..and he finally gave up...ugh...
You could build an Avisynth script to frameserve your avi file with subtitiles to your encoder. Your encoded m2v would contain the subtitles (which would be permanent). Then author the m2v with your ac3 audio in TDA.
Learning Avisynth (if you don't already know it) and build your script will take some work on your part ... however, Avisynth is free and a very powerful tool and worth it (in my opinion). -
https://www.videohelp.com/forum/userguides/153058.php
Use Vobsub
Just make sure you have a folder with your avi in and the srt file together.The avi and the srt must have the same name (Wedding.avi,Wedding.srt)
TDA errors
By siluet in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2009, 08:08 -
convertxtodvd to tda
By marioval in forum Authoring (DVD)Replies: 9Last Post: 18th Jan 2008, 07:14 -
TDA 1.6 menu help
By colt4523 in forum Authoring (DVD)Replies: 0Last Post: 3rd Nov 2007, 19:46 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
TDA 3 Questions
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 16th Aug 2007, 13:03
