can anyone help me I have this movie.mpg which i converted to vob files but now movie screen size is way too small when it was in .mpg format it was ok is there a program to make this bigger
Results 1 to 9 of 9
Do you mean resolution or the size when played? If it's DVD compliant it should be 720 x 576 pixels if full DI.
Authoring shouldn't change resolution.
Check the original MPEG file with Gspot and see what resolution it started with.
Then it would help to say what programs you are using to make the DVD.
Also what have you watched the DVD on, a settop player or just the computer? -
That sounds like a problem with your software player. If it is that resolution you should be able to resize the picture in the player to full screen size. If all else fails, try the free VLC media player.
The software DVD viewing program I use most is PowerDVD. But it is payware. -
Get the latest GSpot (2.52 Beta) - I don't care if you already have GSpot - you need this latest Beta (it's a must for opening MPEGs properly) and load your source file into it, take a screenshot, then load one of the VOBs into it, and take another screenshot. Upload them here with help from this guide. Also tell us what software you used to convert the MPEG to VOB(s) and if applicable, what settings you used.
BTW, if WE'RE helping YOU, the least YOU could do to help US is provide shitloads more information than YOU already have. Your original question is like saying "Help! I washed my car and now it won't start. Why ?" without any indication of the condition of the engine, how much fuel you've got, etc etc. Please post as much information as possible - we can't see your screen from here.If in doubt, Google it. -
ok jimmalenko i have now included snapshots this 1st one is the original .mpg movie
this one is after i converted to dvd ie: vob this snap is the 1st vob
try author and burn it, use for example tmpgenc dvd author. divxtodvd will reconvert the video.
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Font size is sometimes big and sometimes small
By Fire Foxer in forum SubtitleReplies: 0Last Post: 25th Aug 2010, 14:23 -
font size is too small
By snapyou in forum ffmpegX general discussionReplies: 5Last Post: 3rd Jun 2010, 14:21 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
[help] small size good quality
By las7h0p3 in forum Video ConversionReplies: 1Last Post: 6th Nov 2008, 08:27
