MPC used to work fine, now it won't render .ram files. I've tried reinstalling and also reinstalling codecs but nothing works. I get error msg. "failed to render the file" I was trying to clean out some duplicate codecs last week, so I bet this was the problem. I've used winxp to revert to older registry, but still won't work.
Thanks for advice.
Uninstall MPC. Use codec sniper to remove all RM/ram codecs and any other unused or corrupt codecs. Reboot, then reinstall MPC.
Google is your Friend
64-bit real media plugin/codec for MPC-HC?
By cheerful in forum Software PlayingReplies: 0Last Post: 3rd Oct 2010, 07:01 -
MPG files won't play - Windows Media Player 11
By crjackson in forum Software PlayingReplies: 9Last Post: 9th May 2010, 20:16 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
Media Player Classic won't play WMV files?
By majax79 in forum Software PlayingReplies: 8Last Post: 25th Nov 2008, 04:05 -
wmv won't play in mpc
By nfl2k2 in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2008, 09:31
