the two default folders you have in nero express for some reason i dont have cant work out why.
i cant add any folders either when i add files even if there in a ts folder it just puts the contents into nero and i know isnt much of a problem but after some reading on here somewhere i learned that some dvd players look for the audio ts then the video ts folders if they dont find them they wont play.
i have tried create folder also uninstalling niether work
question is this can this cause me problems or should i just ignore it thanks for any help
I never use Express, but I just opened it and the two DVD folders are there. It's true that the audio folder serves little purpose at present, but it doesn't take up any space, so I leave it in. Never found a player that missed it, though.
Are you burning successfully? That's not really clear.
If you have Nero Burning ROM, use that instead of Express.
If those folders are missing, use Nero Clean and then reinstall. Just uninstalling and reinstalling won't always clean everything out.
My method is to copy and paste the VOB, etc. files into the Nero VIDEO_TS folder. Works better for me than trying to overwrite the Nero folder. -
burning so far without a problem and tried the clean tool from nero didnt put the folders back when i reinstalled and i have nero burning rom just wasnt sure if it may cause me problems in the furture if i get a new dvd player hate to have to redo all mine again .
is strange how i dont have the folders but wont let it worry me for now
thankyou for answering though -
Are you definitely using the DVD-Video template ? What version of Nero Express are you using ?
http://members.dodo.net.au/~jimmalenko/NeroExpress.htm should be all you need to know.If in doubt, Google it.
What's the difference between _TS and .ts files?
By Yellow Peril in forum Video ConversionReplies: 3Last Post: 1st Apr 2011, 05:16 -
VIDEO TS/AUDIO TS folders universal?????
By camshiva in forum Authoring (DVD)Replies: 3Last Post: 25th Jun 2010, 12:30 -
DVD Folders - Video TS & Audio TS
By bdr13278 in forum Authoring (DVD)Replies: 20Last Post: 21st Feb 2010, 13:40 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54 -
Converting Video/Audio TS folders to DivX etc.
By supermac in forum MacReplies: 7Last Post: 18th Jul 2007, 09:58
