Hi there,
Im quite new to this stuff and would like some advice please.
Basically what im after is some way of capturing the video from my DV camcorder (non-DV in)then recording the edited footage onto VCR ?
I know that im going to need a FireWire card but im not sure which ones can output to a VCR. Also I want the software/Card/Lead altogether.
Im on abit of a budget and have found these cards sofar, any info on them would be much appreciated :-
SIIG 1394 FIREWIRE DV KIT (3 ports) - £100
AIST MOVIEDVSTUDIO - £55
BELKIN PCI FIREPATH (s ports) - £65
Will any of these do the job that I require ?
Thanks in advance,
Mike
Also Ive got a 3dfx Voodoo 3 3000AGP if this helps/makes any difference.
Cheers,
Mike
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 17:46 -
Need help in choosing a video capturing card - Matrox
By avinash.rao in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2008, 07:49 -
choosing a HAUPPAUGE card
By npereira in forum Capturing and VCRReplies: 67Last Post: 31st May 2008, 04:41 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 10:28
