  1. Hi
    I have downloaded a screensaver that doesn't automatically go in to the screensaver folder. I had to extract it, which I did, and then couldn't find where to put it. I have it stored at the moment in My Received files. I am running Windows XP. Can anyone help please?
  2. Take the .scr file, and put it in your Windows folder.
    Cheers, Jim
    My DVDLab Guides
  3. Thanks, do I just drop it in anywhere in the Windows folder?
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    in system or system32 ..
    but really you can put it in in just the windows folder also .. as long as it is in your path
    but make sure it is not really a virus -- some *.scr file really are .. or some really suck up system resources ..
  5. Thanks very much, screensaver installed successfully.
