Hope someone can help...
When playing a movie vobsub autostarts and shows subs. A little icon shows in the tray. I double-click the icon, click "launch config dialog" and changes the Outline from 2 to 1. Click ok.
Works great.
I close WMP, double-click on another movie, and vobsub reverts to using the default value (2) for the Outline.
Is there any way I can have any of the settings be permanent ? Either in the registry or an .ini file ?
thx
/jim
thx.... but....
I had the old vobsub 2.23. Didn't have the regkey mentioned. Found out about vsfilter 2.36. Downloaded. Uninstalled vobsub. Installed vsfilter.
Now I can't play movies with subs. Rebooted. Still nothing.
WMP start up, says it's playing, but it isn't. The little green arrow pops up in the tray, and I can click it and see it's the new vsfilter.
Using tmpgenc it says "<filename>.... not recognized..."
Help....
/jim
problem with VobSub
By nazim in forum SubtitleReplies: 4Last Post: 23rd Jun 2011, 16:32 -
Vobsub
By leftspeaker2000 in forum SubtitleReplies: 0Last Post: 31st May 2011, 11:41 -
Problem with vobsub 2.23
By mop59136 in forum SubtitleReplies: 2Last Post: 8th Mar 2011, 12:07 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 15:55 -
Avidemux - Save settings?
By Shadarr in forum EditingReplies: 2Last Post: 15th Jun 2009, 11:19
