Im using Nero to burn my DVD and right before I burn, the program freezes up. Any suggestions.
Or remove Nero and reinstall. It's OK for burning, but not much else.
Being that you haven't given any other info, that's about all I can suggest.
EDIT: If you need to uninstall Nero, use the Nero Clean Tool. It takes stuff out the uninstall doesn't. It also solves some Nero problems when you need to reinstall Nero. -
Actually I like Nero, it can do some things you wouldn't think of. It is really slow, but, this isn't a Nero bashing thread so:
Bad media screws up burns in Nero more than anything else, what are u using? -
is it your first attempt at burning DVD?
maybe what you're trying to burn is causing problem.
nero has its knockers but i think it's excellent. -
If you are burning avi's to dvd using the "make your own DVD-video" in nero vision, your problem may be the result of not having the correct codec for the avi file, nero is extremly picky about codecs, and it will lock up if you don't have the right one. although this usually results in the program locking up during the transcoding of that avi file, it sometimes occurs immediately before or during burning as well, i've even had it happen when adding files to the project.
Sony S580 region locking
By cheekiestgrin in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Oct 2011, 20:46 -
Help; Capture Locking Up with Canon Elura 90 DV
By bj4jc in forum Capturing and VCRReplies: 2Last Post: 22nd Nov 2010, 23:37 -
Slow & locking up
By BLSAMPLES in forum ComputerReplies: 7Last Post: 17th May 2010, 15:17 -
Why is DVD Decrypter locking up?
By dphirschler in forum DVD RippingReplies: 11Last Post: 14th Jan 2010, 22:34 -
Subrip2scc locking up?
By Lbrow in forum SubtitleReplies: 0Last Post: 12th Jul 2007, 15:08
