One of my web design clients wants streaming WMV video on his site - have never done this before. He's supplied with DVDR copies of his movies, so I guess I need to rip and encode to WMV.
1. What's the best software for, if possible, simultaneous ripping and encoding of DVD to WMV?
2. Is there a specific resolution/compression I use suitable for WMV streaming?
Thanks!
You could try http://www.divx-digest.com/software/moviepro.html
(it doesn't work here...crashes every time)
Or try tmpgenc xpress, it should support dvd-video input and wmv output but I have never tried it.
Or convert the dvd to mpg, https://www.videohelp.com/forum/viewtopic.php?t=224833 , and use windows media encoder.
check windows media encoder for resolutions and compression. -
A:
2.I would use 320x240/700kbps video/64kbps audio for general purpose video(ie. speech) or dial up.Use 640x480/1500 video/128 audio for high quality video(ie. fast motion,music or high detail) or LAN,DSL,cable.
Best, easiest method for converting DVD files into AVI, etc.
By pcq in forum Video ConversionReplies: 6Last Post: 30th Jul 2011, 13:13 -
Easiest method of internet recording?
By ballantyneguy in forum Video Streaming DownloadingReplies: 2Last Post: 8th Aug 2010, 19:32 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 19:11 -
Easiest method for Mac (Leopard) DVD backup?
By derrek.mcnab in forum MacReplies: 15Last Post: 12th Mar 2008, 20:30 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 04:35
