I finally got a DVD burner recently. Been using Svcd's until now with great success. I have a Mintek 1600 stand alone DVD player that has handled everything I threw at it until now.
I just burned some DVD's (all at 4X speed) and went to view them on my player. The DVD's used were +R and 4X rated. They played fine for about 60% or more of the disk and then began sticking and freezing. This type of behavior happened always in the last 40% or so. Checked several other burns with similar results.
I took the same DVD's and played them on several different PC's DVD drives and they played without incident. I was also able to copy alll of the date from each disk back to my HDD (used DVD decrypter) without a single error.
Based on the above it appears to me that the DVD's were burned successfully, no coasters or anything else.
I have read much about media quality on various forums and in general believed that poor quality media would lead primarily to coasters. ie they should play badly irrespective of the DVD drive. Does this seem to be a correct interpetation?
According to info on VCD help the Mintek 1600 plays both + and - R media. Is it possible that despite this one type is prefered over another?
Finally even if a disk is perfectly burned do DVD players have problems reading different media based on Mfg or dyes used?
Thanks for any ideas that can be offered.
Your interpretation about media quality is not correct. Poor quality media may lead to playback problems, just like you are having. Since you didn't mention the name of your media (are you ashamed to tell us?), I can only guess that you are using the cheapest discs you can buy. With DVD, I learned a long time ago that you get what you pay for.
Yes it is possible that your player may prefer one type over another. I have an old Apex DVD player that will play both DVD+R and DVD-R, but it was really fussy about which brands of DVD+R I used and didn't care which brand of DVD-R I used.
Yes, even if you have a perfect burn, some players may refuse to play the disc based on the dye being used or the manufacturer. I usually will only buy Verbatim burnable DVD discs, with Fuji being my 2nd choice if I can't find Verbatim. I bought Memorex once and I think 4 out of 25 discs were coasters, so I never bought them again.
Problem using Media Player Classic home cinema player
By True Colors in forum Newbie / General discussionsReplies: 7Last Post: 18th Apr 2010, 07:30 -
Media Player 9 Problem
By bevills1 in forum ComputerReplies: 3Last Post: 3rd Aug 2009, 10:52 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
problem with VLC media player
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2007, 05:44 -
Problem with DVD Playback on Windows Media Player.
By Cereal Bawks in forum Newbie / General discussionsReplies: 5Last Post: 29th Jul 2007, 15:11
