  1. when trying to shrink dvd (man on fire) i get FAILED TO READ "d:\" Data Error (cyclic redundancy check) when disc is being analysed and will no continue any one got any info please..........mickdee259
  2. Member pchan's Avatar
    Mar 2003
    Singapore
    Rip the disc to your hard disk using DVD Decryptor. Use DVD Shrink to shrink the video in your hard disk.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Do an all forums search or a google search for "cyclic redundancy check".
    If in doubt, Google it.
  4. Try cleaning the disc or grinding it with one of the many available products out there.
    Usually, the most common cause for this error msg is a dirty or scratched disc.
    Sabro
    www.sabronet.com - It's all you need...to know
  5. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Yep. Problem lies with the physical condition of the disc. Thats when you usually get "Cyclic Redundancy Error" occuring.
  6. thanks everyone will give replies a go.............cheers.........mickdee259
  7. Member NoFace's Avatar
    Jan 2005
    wherever I am
    When no other prog works (DVD Shrink, DVD Decrypter, Windows copy file, etc.), DVD Fab does. Don't know why this is, maybe someone here can tell me? Does it ignore the error?
    occasionally larger than 255 characters
    Mar 2004
    Ireland
    I've gotten this message a few times when using original disks that are red in colour. I never a have a problem until I use these disks.
