  1. I'm using virtual dub to cut out the sections of the video that I need. If I use the 'Save Old Format Avi' selection once i've selected the in/out points, will the outputted file have the exact same quality as the original?
    Also, if the original file is mpeg instead of AVI, how do I keep the quality the exact same for the outputted file?
    you want to look for something that can do a "stream copy"..i believe vdub will do this..i use womble mpeg video wizard and i love it! it essentially just copies that section to another mpeg file without re-encoding so you don't loose quality. It also is MUCH faster than re-encoding...
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Just go to Video > Direct Stream Copy and then Audio > Direct Stream Copy. No need to go to Save Old Format AVI, just use Save as or Save as AVI (or whatever the "normal" save option is).
    If in doubt, Google it.
