Against my advice they wanted me to get them a Everex GS28, but they needed a floppy
I called and emailed Everex and they said NO problem but you'll have to supply the FDD cable....WRONG! I had to mod the case with a drill so the FDD screws would work. Plus, they use the cheapest crap on the market (IMO) in these things
Then again, this looks to be a great service contract for the reasons above
Results 1 to 12 of 12
what about an external floppy?
or a virtual floppy that is then transferred to a cd-rw?
The client had about 200 floppies they used!!!!
I was against it my good man...but they insisted.
External?.....Remeber they took the cheap way
I was lucky with my HP laptop. They had a USB floppy for free after rebates. Handy little bugger. I use it occasionally with my other computers without a fd drive. I quit installing floppy drives a year ago. Never missed them. If all else fails, I use the USB floppy.
; With a flash drive for backup.
floppies are sooooo unreliable! surely those people have been burned more than once by using floppies for their stuff..
Actually, no. I told them the same thing. I suggested either using a jump drive or CD-RW....
They said that everyone they deal with uses floppies and they need to too, and they've never had a problem before.
This same client has never done a backup either
Good money for you. They'll pay in the long run. I know you said cheap, but all the business machines I build have a RAID 1 array of two drives and a backup device of some kind. They may not use the backup, but at least the array is there for hard drive failure.
Floppies aren't so bad. I have 10 year old Sonys and Maxells I still use once in a while. 3M/Imation are crap.
-Evan- -
they don't have any servers
So? RAID is an excellent idea for workstations as well. Adding an additional hard drive and basic controller costs less than $125. Much easier (and cheaper) than restoring data. But if your paid by the hour to clean up their messes (been there), more power to ya.
-Evan- -
I guess you failed to read the subject line and my first postOriginally Posted by QuaiBoy
I don't even run fault tolerance on my computer....I backup weekly though -
maybe you can at least get them to use WinImage to make backup images of their floppies
When the client says "I've never had a problem before", it basically means "end of discussion". I've gone as far as buying clients NICs, minihubs, RAM - anything under $100, just to save myself the aggravation, and then charge them back with a higher number of hours on the invoice.
Client not paying....question!
By dmdobsonjr in forum Newbie / General discussionsReplies: 13Last Post: 9th Jun 2010, 18:05 -
Embeddable MPEG2-TS Streaming Client?
By Penumbra in forum Video Streaming DownloadingReplies: 0Last Post: 8th Apr 2010, 11:42 -
DVD skipping for Client - tried everything we can think of!
By trevmarps in forum Authoring (DVD)Replies: 15Last Post: 2nd Apr 2010, 16:46 -
Free FTP client
By zoobie in forum ComputerReplies: 2Last Post: 1st Apr 2009, 03:49 -
remote desktop client
By Tom in HD in forum MacReplies: 2Last Post: 10th Dec 2007, 17:17
