I'm a newbie. I've been doing this for about 2 weeks, and it's been working fine until now.
I'm using NeroVision Express to edit and burn dvd's that I've recorded on my standalone DVD recorder. It has been taking about 20-30 minutes to transcode and burn about 4 GB onto a DVD.
Now it has suddenly started taking 3 hours to transcode. I've tried it on several different VOB's, so that's not the problem.
I did see a post about having DMA enabled rather than PIO mode. I checked my IDE's. The primary channel says DMA.
The secondary channel has "DMA if available" selected, but then it says current transfer mode on Device 0 is PIO. I can't seem to change that one. The transfer mode on Device 1 is DMA.
Does anyone have any ideas on what caused the sudden change? I haven't changed any settings on my computer or in Nero.
Thanks!
What is device 0? If it's just about any of your drives, DVD or HD, the normal method if your drive has reverted to PIO mode is to delete the channel it's on and let the OS re-install it and when it reboots it hopefully will reset to DMA mode.
Reverting to PIO mode is a fault with XP. If it has several tries to read a bad disc, it changes to PIO mode. You will need to do the above to reset it.
Converting 6 files taking over 10 hours
By ChadBling in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 07:03 -
Video taking 18 hours and counting to upload...
By Nintendo Fan in forum Video Streaming DownloadingReplies: 3Last Post: 24th Feb 2009, 19:33 -
Ulead DVD MF6 taking 11 hours?
By Hondamaker in forum Video ConversionReplies: 1Last Post: 18th Jan 2009, 15:14 -
DVD-RB with CCE taking 18 hours...
By hiimbored in forum DVD RippingReplies: 2Last Post: 23rd Nov 2008, 17:03 -
Burning time taking 2 hours???
By Its Pink Ninja in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jun 2007, 17:55
