    Nov 2000
    Umeå Sweden
    Hello can some one help me with this problem? How can I rip angle 1 from Star Wars 1 The phantom menace with smartripper? Thank you for your help in advance.
  2. movie mode in smartripper should automatically select the right angle for u
  3. if that doesnt work use Flask to encode so you can select the angle....to get better quality use the Panasonic Plugin to give you the best quality with Flask or Xmpeg
    Nov 2000
    Umeå Sweden
    Thank you Spice Boy it works.
