I am running Media Center 2005 and I am trying to burn some recorded TV programs to DVD to view in my upstairs TV. There is an option to create DVD in media center and when I use this option, it starts to create the DVD, gets to about 1% complete, hangs a bit and then spits out the CD and says "there has been an error". The burner LED light does not come on and I can not hear the drive spinning.
I've created Data DVDs and I've also used Pinnacle Studio 9 to create a DVD of a small video clip and it worked OK. The drive also works fine as a DVD ROM. So it seems as though this is not a hardware problem with the burner (BTW, the burner is a MATSHITA SW9585 if that helps). I also believe media center is using sonic encoders.
Does anyone out there have any ideas and/or experience with DVD authoring from within Media Center 2005?
Results 1 to 1 of 1
Which codec for Media Center 2005?
By Gyrobob in forum Software PlayingReplies: 6Last Post: 27th Nov 2010, 22:20 -
Trouble playing ripped DVD with Windows Media Center 2005-bad country code
By nzdreamer55 in forum DVD RippingReplies: 3Last Post: 6th Mar 2010, 10:28 -
Windows Media Center 2005 XP and DXVA?
By ID3_Freak in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2010, 16:58 -
Windows Media Center 2005 and ISO Playback
By zagortenej in forum Media Center PC / MediaCentersReplies: 7Last Post: 20th Oct 2009, 11:01 -
XP Media Center 2005 playback issues
By trooper11 in forum Media Center PC / MediaCentersReplies: 3Last Post: 14th Nov 2007, 01:31
