is there any way to find out the frame rate of a real media video file .rmvb?
When the video clip is playing in RealPlayer, try going to File/Clip Properties/Clip Source on the menu. You should see the frame rate listed in one of the streams.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
RMVB shell extension can tell you
http://www.video-tools.com/modules.php?name=Forums&file=viewtopic&t=375
However rmvb files can be VFR so it might not be 100% accurate.
rmvb help
By aimbdd in forum ffmpegX general discussionReplies: 4Last Post: 7th Aug 2008, 20:22 -
Help on RMVB
By JohnConstantine in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 09:30 -
RMVB
By magius in forum AudioReplies: 4Last Post: 7th Jan 2008, 10:26 -
rmvb to dvd?
By asdfprou in forum Newbie / General discussionsReplies: 8Last Post: 29th Nov 2007, 02:20 -
RMVB file???
By BigCol in forum Authoring (DVD)Replies: 1Last Post: 13th Jul 2007, 18:23
