Hi i am trying to convert an avi with tmpgenc to dvd..BUT..the resulting file is way to big to go onto dvd its like 8 gig...I dont want to split it either..i want it on one disk i know it can be done but how???
And yes my disks are only 4.7gig ones
Please help ty![]()
Before you re-encode try authoring and use DVDShrink to reduce the size. If it's not good enough then you'll need to re-encode with a lover birate. You can find a bitrate calculater in the tools section.
Or if you know the length of the video, I usually use the average of 8k for 1 hour, 6k for 1.5 hour's, 4k for 2 hour's, you get the picture, the longer the video the worse the quality will be.
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 03:09 -
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 01:41 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51 -
DVD to one big VOB ?
By rindless in forum DVD RippingReplies: 5Last Post: 19th May 2007, 05:42
). And if your video has PCM/Wav audio, try AC3...MP2 audio would also work in PAL land.
