I am trying to use SVCD2DVD to convert a DIVx video to DVD. Everything seems to be functioning properly but the final product. When I try to burn the ISO file or try to create the DVD using the Video and Audio folders I get something like "File size to big". I am putting this on a 4.7GB disc. The size of the iso according to explorer is 4.38 GB or 4,710,211,584 bytes. What is the maximum size I can fit on a DVD+R?
Just as a note I have the CD size under the Bitrate Menu set to 4300. Should it be lower? The obvious answer seems to be yes.
A single-layer DVD+R should hold 4,700,000,000 bytes, so you will need to lower your target/average bitrate slightly.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
Avi2DVD file access denied
By Imeil in forum Video ConversionReplies: 1Last Post: 27th Aug 2011, 08:29 -
Avi2DVD help Iso too big
By martial4rtist in forum Newbie / General discussionsReplies: 12Last Post: 9th Apr 2011, 17:41 -
No audio in AVI2DVD w/CCE SP from MKV file?
By XyBeRz in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2009, 13:13 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 21:20 -
Does Avi2Dvd only support creation of ONE file?
By m93 in forum Authoring (DVD)Replies: 0Last Post: 21st Jul 2008, 03:16
