I don't get what the hek I'm doing wrong here!!!!
I drop 2 clips into premiere. Edit out some parts I don't want and render it out to one .avi file.
Only problem is the audio is all fine, but the video of the first clip never shows up.....it's gone. So now clip ones audio is playing while I'm seeing the video to clip two. Needless to say after about 5 times of rendering this out and no luck I'm gettin a little PO'd
Anyone have any suggestions. I also can't check the help files in premiere as when I click on them stupid premiere just crash's.
Why don't you post your problem here:http://www.adobeforums.com/cgi-bin/webx?14@@.1de9c1bf. You stand a better chance getting a response.
What is your source file codec??
After you've cut your masterpiece, double click on the numbered time bar, and you'll see a work area bar appear..
Hit "Enter" and rendering will happen (assuming you have a red line just under the time bar)..The red line indicates that the source file isn't the same as the project settings..
After you've rendered, you should play back the video and see everything in the project monitor..
If at this point everything is okay, then Export to .AVI, with "work area bar" selected...
If after rendering, you don't see anything in the project window, then i'd suspect a codec issue...
Also quickly doublecheck that you didn't poke the eyeball on the Track number..
Good luck!! -
So you have your project settings to AVI with codec set to huffyuv? Are your import files huffyuv as well? And you are outputting huffyuv?
What are the audio settings?
I think you are seeing the results of mismatched project vs import file settings. Premiere needs to convert (aka conform) import files to project format.
Lots of info here
http://www.google.com/search?client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial_s&hl=en&q=Premiere+huffyuv&btnG=Google+SearchRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
editing a dvd or bluray in Adobe Premiere Pro CS5.5
By caretaker1379 in forum DVD RippingReplies: 5Last Post: 16th Mar 2012, 17:44 -
Adobe Premiere Pro CS5 Editing Effects?
By Napy666 in forum EditingReplies: 1Last Post: 20th Aug 2010, 19:43 -
AVCHD EDITING IN Adobe Premiere CS4
By Don Man in forum EditingReplies: 10Last Post: 4th Jun 2010, 16:41 -
Adobe Premiere and editing of long movies...
By arminio in forum EditingReplies: 6Last Post: 25th Feb 2008, 19:07 -
Editing and exporting already compressed video in Adobe Premiere
By Rocky88 in forum EditingReplies: 4Last Post: 31st Jul 2007, 09:52
