I've had plenty of hard drives fail but never like this.
Its just a storage drive, no system files. I immediately tried to copy files from it when I heard the taletell clicking sounds but it would just churn for a long time then error out. Then any attempts resulted in a BSOD and now I can't even have the drive hooked up without getting a BSOD at startup.
I've tried replacing the cable and hooking it up to various inputs (both IDE chains, and a raid input.) I'd like to recover some of the files but there's no way I'm paying for a full blown archival service.
ANY suggestions?
Invest in a USB/IDE External case. You will find it incredibly useful in recovering info from bad hard disks. I've seen this before. For some reason the IDE bus will lock whereas the USB doesn't. If the data is unrecoverable, the drive will not appear when you plug the USB cable in. After you've run this test, you will have yourself an external box good for any internal HDD or internal optical drive in an external environment. Usually cost anywhere between $30 - $50 USD.
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
BSOD
By Willy5157 in forum ComputerReplies: 10Last Post: 19th Oct 2009, 15:55 -
BSOD while trying to display
By src2206 in forum Software PlayingReplies: 7Last Post: 11th Jun 2009, 14:27 -
BSOD, help would be appreciated.
By chipsndukes in forum ComputerReplies: 11Last Post: 27th May 2009, 21:06 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38
