I have a movie with 2 file A and B, and i download it from BT
The problem it, when i see if with Jet audio , both file work good with sync subtitles
BUt when i try to use mainconcept to convert both file to 1.mpg and 2.mpg
and authorize them with dvdlab, of course there are 2 file in my Dvd,
With Dvdlab, i make a link to autoplay file 2 after file is finish
But problem here is, after 10mins playback with the file 2 in my dvd , i have some kind of out of sync subtitles,
Yes, i tried to join both 2 avi file to 1 and authorize them, but i still have the out of sync prob with half of my Dvd
Anybody can help me this ?
you have said mpg files - did you use elementary streams (seperate video and audio streams) or program streams (a combined video/audio stream) ? If it was the latter, DVD Lab would have given you the option to demux the streams. If you didn't, this might be the cause of your problem.
Read my blog here.
Joining .ts files is always a/v out of sync
By PetitDragon in forum DVB / IPTVReplies: 10Last Post: 12th Mar 2011, 13:02 -
QT files out of sync
By rotuts in forum MacReplies: 8Last Post: 28th Jan 2011, 16:31 -
Many Video Files Gone Out of Sync
By rogue20 in forum AudioReplies: 2Last Post: 30th Nov 2009, 07:59 -
ts/m2ts files audio out of sync
By zwok in forum Video ConversionReplies: 0Last Post: 4th May 2009, 05:46 -
Help with mergeing Ts files ..without getting sync issues
By camlachie in forum DVB / IPTVReplies: 2Last Post: 7th Apr 2009, 15:09
