I was trying to back up my copy of Beauty Shop using DVD Shrink. I first used DVD Decrypter to put it on my hard drive. Then opened Shrink to make it fit. But with everthing on automatic ratio it still went over the size limit. I even tried to put everthing on custom ratio but could not drop it down far enough to get it to fit. What can I do to make it fit including all the extras and menus?
DVD-Rebuilder works wonders (for me, at least)
Rip with DVD Decrypter or (DVDFabDecrypter), install DVD Rebuilder (using the rockas installer), process with DVD Rebuilder, then burn with DVD Decrypter.
Don't forget to send a donation for DVD Rebuilder (donate before v1 final is released to get the Pro version! -
Doesn't the R1 version have a widescreen and fullscreen version? You can possible fit everything if you removed (blanked) out one of them. Either with PgcEdit or VobBlanker. You can then also remove your aspect ratio menu (WS/FS) with this guide.
Yep... i never tried the whole thing... i just deleated the fullscreen part and kept the widescreen part (i hate fullscreen) and it came out fine....Originally Posted by DoubleShadowIce
with menus, ect. they need to just do away with fullscreen altogether :P
I did mine with just DVD Decrypter & DVD Shrink.... as always 8)
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
What do you shop online for?
By johns0 in forum PollsReplies: 15Last Post: 19th May 2010, 16:19 -
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 18:43 -
Computer Repair Shop Software
By Poppa_Meth in forum ComputerReplies: 5Last Post: 19th Jan 2010, 05:52 -
PROBLEM: Animation Shop Won't Export To Paint Shop Pro 8
By Aaron1927 in forum EditingReplies: 1Last Post: 10th Jul 2007, 09:44
