i hope im posting this in the right forum......well here it goes.......i have a avi and converted it 2 a mpeg using tmpge...ok no prob.....i play the mpeg on my computer no prob......i burned the mpeg to a cd no prob.....i play the vcd on my computer no prob.....heres where the problem comes....i play the vcd on my standalone dvd player and for some reason it seems to fastfoward certain parts of the movie....which in turn throws the audio off by about a sec or two......then everything comes back in sync......but it usually does it about every 10min during the video....i have a daewoo dvg 5000n......is it my dvd player or is it that i am burning the mpeg wrong.......cuz i tried about 5 times and all came out the same........messed up.....if anyone has any idea pleaze let me know.......peace
Results 1 to 9 of 9
Hi naloryder!
Welcome to the world of VCD!!
First up, it could be that your DVD player just isn't up to the task of VCD playback - check the compatibility list (left menu <-- ). Also, it maybe faulty.
If I were you I'd rush off a quick email to Daewoo tech support and check what the exact specs are on your model.
After that you can reply on this forum giving more details about how you encoded and burnt your VCD (eg.Settings used on what software etc).
It could be that your using a video bit rate which is too high for your DVD player - ie. you made a non-standard VCD.
This could make your DVD playback jumpy (but I've never heard of the jumps coming as far apart as 10mins!)
One bit of (obvious) final advise is to make sure you're using a correct VCD template in TMPGenc (either NTSC or PAL as appropriate).
Hope this helps a bit.
Speak soon,
Sue. -
thankx for your help sue.......sorry i took so long to write back its just that this is my third time writing because i didnt know my last two messages were not sent....but here it goes......i check the compatiblity list and it does say that the daewoo is capable of playing vcds and stuff.......howener i did not e-mail the company because i do not know what to ask them(didnt know what you meant by specs?).......the program i used to encode the file was tmpge and here are the details about my avi....audio format - MPEG Layer-3,55 kBit/s, 22,050 Hz, Stereo.....video format - 352 x 238, 24 Bits, 78387 Frames, 29.970 Frames/Sec, 39 KB/Sec, DIVXMPG4 V3........so in tmpge....under video i used high resolution(slow).....and under advance source aspect ratio i put vga 1:1 and under video arrangement method i chose custom center 352 by 205 pixels......i did not change nothing else......the template i loaded was videocd(pal).....im pretty sure that was the one i was suppose to choose.....and i use easy cd creator 5 to burn the mpeg.......i went add item.....dragged it to the other side and then creat cd form layout.....i then chose track at once and finalize cd then hit record.....i hope this information is useful to find out what im doing wrong or what is wrong with my vcds and thankx again for helping me out........i hope this one gets sent
It seems you have created a noncompliant VCD. Below are the specs I got from Phillips...
Video: MPEG-1 at 1.15 mbps, PAL (25fps) 352x288, NTSC (I am not sure about the frame rate but it should be either 23.97fps or 29.97fps) 352x240.
Sound: MPEG-1,Layer II at 224kbps and 44.1 kHz.
Hope you can make some use of these specs to fix your VCD encoding...It looked to me as you where trying to encode an AVI with the wrong resolution and wrong sampling frequency as well as wrong framerate 29.97 in a PAL vcd will not work...
yo bacardi thankx 4 ur help........so i have a question......i opened my avi and went to view and statistics and the frame rate is 29.97 and the actual rate is 28.04.....so which template should i use?....and if i want to change the way the video looks by making custom center which source output should i use? if u could help me out on this i would really appreacite it......thankx
I would probably use a template for NTSC 29.97 fps since this seams to be the easiest way of keeping the A/V sync intact. But if your stand-alone player can't play NTSC VCDs or your TV can't display them, then you will have to try and convert the AVI to PAL which I'm not to familiar with. When it comes to source out put, I'm sorry but I don't have a clue what you are talking about.
By the way check the guides at http://www.doom9.org if you haven't already.
Good Luck -
thankx again for helping me out......and sorry i meant source aspect ratio not source output.........sorry for the mixup.....so if you know which ratio to use could you please let me know......thankx
I would try to set the following:
input - 1:1 VGA and center (customsize)352x238
output - 4:3 NTSC
But I'm not sure how this will look so you might have to playaround with the input and try 4:3 and different videoarrange methods....
Hope you will be able to make some sense of this....
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
Need advice on standalone players most tolerant of DVD-Rs
By psychotronicfilms in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Sep 2008, 14:26 -
DivX and encoding for Standalone DVD Players
By Sandbar in forum Newbie / General discussionsReplies: 5Last Post: 20th Apr 2008, 20:16 -
Computer DVD players vs standalone
By JudgeGarth in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2007, 11:00 -
Standalone 5.1 dvd players
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th May 2007, 15:50
