Hello everyone I have a few moovies I would like to watch with my dvd player but the big problem is they are in .bin/.cue format, both moovies have 2 .bin files, so I was wondering how i could make the conversion. Usually when i have 2 .avi files, I just merge them together then convert to VOB files and burn with InterVideo WinDVD. Any help would be great! thanks!
You could view them with Daemon Tools or exract them with ISOBuster or others or just burn them with many programs, such as Nero. Look in the 'Tools' section to the left under 'ISO/Image'.
I would view them first to find out what format they are, then extract and convert. -
BIN/CUE is just a disc image set. BINs could have any files in them, so you gotta extract whatever is in them and then take the appropriate action depending on what you have. Check out the stickies at the top of the Newbie / General forum - there's one there called "How to convert/extract ISO, BIN/CUE ..." or something similar.
If in doubt, Google it.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Converting .mpeg files to watch on DVD?
By prankstare in forum Video ConversionReplies: 7Last Post: 8th Jun 2008, 20:41 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
