hey all I need help I have A movie that I Just used ulead to create and its 901MB mpeg file I need to burn to cd to make into VCD so I can watch on standalone DVD player well im gonna get to the point ok I Open the file in Virtual Dub to split it into two parts to make two VCDs so they both will fit on two disks and it gives me this message when I try to split them into parsing interleaved MPEG file ok it goes threw that then I set my mark in and go to about 1 hour of the movie and set my mark out to split it and then I go to file and save as .avi and I save it and I get this message "You are about to save an uncompressed AVI file,Which may be very Large. If this is not a temporary AVI file, consider using video compression to save space. The video mode must be set to full processing mode for compression to work.
Why are you using VirtualDub to split MPG file ? use TMPGEnc, go to File / MPEG Tools, and use the Cut & Join feature.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36
